Author Topic: New Injection Lines  (Read 4565 times)
Jack Jones
  • Canada, ON, Milton
New Injection Lines
« on: February 11, 2014, 03:47:09 »
Can anyone confirm if the replacement injector lines from Mercedes are Cadmium plated as the original lines were?
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
Re: New Injection Lines
« Reply #1 on: February 11, 2014, 03:58:47 »
I haven't seen a replacement line, but I doubt seriously it would be yellow CAD. It would be more like yellow zinc which looks similar to yellow CAD but isn't as durable. I haven't seen one replacement part lately from Mercedes that was yellow CAD. I think CAD was being phased out by the time our cars were made.
RonB
  • USA, MN, Cottage Grove
« Reply #2 on: February 11, 2014, 04:30:38 »
If I may ask why are you replacing the lines. Just clean the inside of them and re-finish...
Easy way to clean the inside is to take a old bike brake cable - fray the end - pass it thru the line and the attach a drill to the end that is not frayed and pull it back and forth thru the line to clean any crud that in there. Attach a rinse system to one end flush out with brake fluid.
Previously FULL Member twice with over 500 post
71 280SL - SOLD on BAT
97 E420      SOLD
85 300D      SOLD
85 R107 380SL
07 Volvo S60
Jack Jones
« Reply #3 on: February 11, 2014, 21:44:56 »
I have a lot of corrosion on the outside of the lines. Bead blasting does a nice job on areas that are not damaged but doesn't eliminate the deep corrosion marks.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
W113SL
« Reply #4 on: February 11, 2014, 23:27:45 »
I bought some replacement lines about ten years ago and they were yellow dichromate finish.  Not sure what the base plating was though.  They held up well enough.
Pete Lesler
W113SL
« Reply #5 on: February 12, 2014, 03:31:22 »
I concur with Wallace; extremely unlikely that (unless NOS) a new line would be cadmium plated. That does not prevent you from getting your new lines plated in cadmium; I have done that with new parts that were incorrectly finished. What comes to mind immediately is the automatic transmission filler tube. New ones from MB are now painted black. I bought a new one (a mechanic failed to double wrench it at the transmission end, twisting it to the point of cracking but no leaking; I saw that as trouble waiting to happen) and immediately sent it out for true cadmium plating with a gold phosphate wash. The cadmium does indeed hold up better in the engine bay than zinc.
« Last Edit: February 12, 2014, 12:26:24 by mdsalemi »
