Author Topic: Correct screws for int. door trim  (Read 4538 times)
Clayton
« on: February 27, 2014, 20:10:20 »
Does anybody know the correct screws for the chrome pieces that attach to the interior side of the door around the hinge. There are 3 pieces. 2 that secure the rubber seal and 1 larger piece on top. In removing mine, I found many different types. I am thinking, rounded head, tapered and blunt point. Bueller?
ctaylor738
  • USA, VA, Falls Church
Re: Correct screws for int. door trim
« Reply #1 on: February 27, 2014, 23:53:20 »
They are chrome, round head, "Phillips" screws.  They are 2.9 mm in diameter and 9.5 mm long.  I believe they have a blunt tip.
The Mercedes part number is 007983-002203 and the little buggers list for $3.40 apiece.  I couldn't find a cheaper screw that would work.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
« Reply #2 on: February 28, 2014, 00:42:14 »
Take a look here: http://www.sl113.org/forums/index.php?topic=14342.0 - Reply #4
where I have listed all of them.
Clayton
« Reply #3 on: March 01, 2014, 02:20:24 »
Great info. Chuck and Alfred, thanks a million!
hkollan
  • Spain, Castilla-La Mancha
« Reply #4 on: March 01, 2014, 08:52:47 »
Here is another  tip that might be helpful if the screwhole for these moldings is slightly enlarged.
Its  MB part no. A000 990 10 36. Its an identical screw except that it has a thread of 3.2 mm but still with the small screw-head of the 2.9mm DIN 7983 screw.
Hans
« Last Edit: March 01, 2014, 13:05:26 by hkollan »
Hans K, Cuenca, Spain
« Reply #5 on: March 01, 2014, 08:57:43 »
Another trick that can be done is with the use of fine copper wire.  By putting fine copper wires in the hole before using your existing screws, but the hole has enlarged then the softer copper will sometimes squash into the thread and allow a firm take up of the old screw threads and hold.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Clayton
« Reply #6 on: March 02, 2014, 02:05:20 »
Thanks Hans, I just ordered 2 of them today. If the hole is still too large....I'm going with that copper fix. Does anyone know where to get the 3.9 x 9.5mm cad. or zinc screws with the blunt tip? Mercedes said 007983-003335 is no long valid. Is David Gallon still the guy?
Flyair
« Reply #7 on: March 02, 2014, 07:19:08 »
just in case, you can check with SLS shop. They have a page in English and can also advise you in case of doubt
service@sls-hh.de
http://www.sls-hh-shop.de/en/230-280SL-W113/
Here is what they offer on Ebay
http://www.ebay.com/itm/Mercedes-SL-W113-Pagode-Chrom-Schrauben-Schraube-/300885241161
Alternatively, have a look here
http://stores.ebay.de/chromschrauben/MERCEDES-Pagode-W-113-/_i.html?_fsub=3&_sid=207494435&_trksid=p4634.c0.m322
Stan
2011 SL550 AMG
2011 GL
2015 GLA
