You can use the search function to help with the wood trim question (go to search, then "wood trim" as the search string, and limit to topic only).
I did a little poking around, and appears that walnut is the wood, keep in mind it is a (very) think veneer. So be careful with sanding, stripping, etc. There is a lot of information on the site about what others have done. The wood trim on the Pagoda is nowhere near as complex as the big coupes and cabs. It was also a choice of one of one, again not like the big coupes/cabs, where you could get some pretty spectacular pieces.
