Author Topic: Alternative alternator mounting bracket  (Read 3434 times)
510bluz
  • USA, IL, Oak Forest
« on: March 26, 2014, 01:02:04 »
I just got the a/c alt bracket off my 1970 280. What a pain! Am not putting a/c back, so I need to find what other cars used the alt only lower mount & do I need to change the water pump pulley to match? Power steering belt was way easier than what most posts have described when I found the last adjuster under the pulley. Thanks for any help.
Re: Alternative alternator mounting bracket
« Reply #1 on: March 26, 2014, 03:02:16 »
Most W108and W114 six cylinder sedans of the era had the cast iron lower bracket. It must be a six cylinder and 1968 through 1972. Sedans of that era, even 280 SEs used a simplified AC bracket and the alternators remained below.
Timthebizarre
Alternator belt
« Reply #2 on: May 01, 2014, 23:09:33 »
 Run me through the changing the alternator belt again? The belt I got for 280 sl 1970 is 940 mm. Tensioning belt? There appears to be little adjustment. The adjuster ...run me through it again please. Thanks very much
« Reply #3 on: May 02, 2014, 01:07:33 »
The type of adjuster can vary. Do you have AC?
