Author Topic: Add Power Steering  (Read 3727 times)
Donie
Add Power Steering
« on: March 27, 2014, 23:25:18 »
Is there any reason why power steering can't be retro-fitted to a 1966 230 SL which does not have it at the moment?
Then there is the question of where to source the kit preferably second-hand.
Has any forum member done this that could offer any tips?
George Des
Re: Add Power Steering
« Reply #1 on: March 28, 2014, 00:06:05 »
The short answer to this is Yes, it can be done. contact Jim Villers a member of this Group who recently wrote up an article in the Group Magazine that explained in detail how he did this on his car.
Donie
« Reply #2 on: March 28, 2014, 09:33:25 »
George,
I'm very grateful for that valuable piece of information, which will be of immense help.
I've PM'd the member.
ctaylor738
  • USA, VA, Falls Church
« Reply #3 on: March 28, 2014, 17:01:07 »
Sent you a PM about some parts that may help you.
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
« Reply #4 on: March 28, 2014, 18:55:51 »
Use the search function. There's plenty of information on here about how to do it.
Most of the parts can be sourced from a saloon of the period (280SE for example) but you will need to shorten your steering column by 40mm.
Whether it's difficult or not depends on the skills of whose doing it!
rutger kohler
« Reply #5 on: March 28, 2014, 19:37:03 »
Would also suggest if you are going to use a W108 unit you look through Andy Burn's posts or contact him as he researched this subject meticulously and found you need a W113 power steering pitman arm.
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
