Author Topic: Hard top fitting  (Read 4535 times)
Linda
Hard top fitting
« on: March 29, 2014, 23:48:12 »
Hello - just had my 1969 280SL Californian renovated and hard top roof fitting back on incorrectly! Showing a small gap around the sides? Have we missed a part or seal? Or maybe fitted a seal the wrong way round? Any help out there? Thanks - Linda
Rolf-Dieter ✝︎
  • Canada, ON, London
Re: Hard top fitting
« Reply #1 on: March 30, 2014, 00:16:03 »
Hi Linda,
Click on "Search" above then type
Hardtop fittings
You will find your answer in the thread  shown as "Hardtop fitting" Scroll down to the thread with that subject line then open it and read the posts .. We all have a gap all around ....  no worries :) hope this is what you meant
Note, however, the boys are talking about a 1/2 inch gap, that is a bit much I think on my 280 SL 1969 it is more like a1/4 inch gap all around. Do make sure all your three locks are engaged correctly and locked (the two along each rear side window and the one for the center rear that you find the lock on the rear back inside wall behind the driver seat)
« Last Edit: March 30, 2014, 00:35:49 by Rolf-Dieter »
Flyair
« Reply #2 on: March 30, 2014, 04:27:05 »
We all have a gap all around ....  no worries :) hope this is what you meant. Note, however, the boys are talking about a 1/2 inch gap, that is a bit much
R-D
I checked carefully this morning standing in front of a mirror and can confirm that at least in my case I didn't notice any gap.
Now I will check if maybe my Pagoda has one...
Stan
2011 SL550 AMG
2011 GL
2015 GLA
Rodolfo
« Reply #3 on: March 30, 2014, 06:02:20 »
Technically speaking RD is right : looking at the mirror, you notice that around your body is an immense space ( it is in fact the start of space ) . So or your mirror is shaped as your body or you  ignore the gap !
« Reply #4 on: March 30, 2014, 06:30:14 »
I think Stan was only looking from the front in the mirror and did not look at the rear side where I am sure he will find a gap. :D :D
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Flyair
« Reply #5 on: March 30, 2014, 08:50:33 »
Garry,
couldn't spot mine, but would not look at yours neither ;D ;D
But let's try to pretend that we are strictly professional, so...
Linda, check the picture below and see if the gap in your HT is larger than this one... I think that 1/3 inch is quite OK.
Moreover, maybe the larger than expected gap is due to the very fact that your HT just underwent renovation and if you fitted new seals, they need time to settle.
« Last Edit: March 30, 2014, 09:00:05 by Flyair »
Stan
2011 SL550 AMG
2011 GL
2015 GLA
