Author Topic: Valve Stem Seal Kit  (Read 3744 times)
Ph2ocraft
Valve Stem Seal Kit
« on: April 04, 2014, 15:48:16 »
Where are you guys/gals purchasing your valve stem seal kits?
I didn't have luck locally :(
127 586 01 05, Valve Stem Seal Kit
Jack Jones
  • Canada, ON, Milton
Re: Valve Stem Seal Kit
« Reply #1 on: April 05, 2014, 02:54:22 »
Call Mercedes!
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
Ph2ocraft
« Reply #2 on: April 05, 2014, 04:31:57 »
That's what I did.
I just hate paying over 100 bucks for something that costs less than 23 bucks.
« Reply #3 on: January 17, 2015, 05:39:12 »
What 23 bucks?? Way too much, how about $15!!
http://www.ebay.com/itm/351236466265
« Reply #4 on: January 17, 2015, 06:27:22 »
230SL valve seals are always more than 280 or 250 seals. Make sure you install the seal dry or it will pop off.
« Reply #5 on: January 18, 2015, 17:14:37 »
I would see if anyone makes seals out of some "Rubber" material rather than the teflon or plastic of the ebay seals.  They will tolerate a lot more in terms of loose valves etc.  Not sure if the 230's do it but the M130 2.8 engine has a tendency to have the valve guide to slip in the head casting so rather than the valve riding in the valve guide the guide moves up and down in the head along with the guide.  I replaced my seals before Joe Alexander pointed me to the real problem.
