I have a 230 sl 66. manual.
Today I rebuilded the differential (4.08 to 3.25 and all new bearings). There was not a problem, normal mechanical work, which was rather straight forward. Also thanks to great advices here.
But:
I also had a broken U-joint/slider on the right rear axle (actually the main reason why I opened the rear axle).
After a long search, I finally found a shop which had a U-joint for sale.The seller told it was new. (not so cheap as a result). I bought it.
Now I have two questions:
1) is this U-joint normally with the inner slide included? So I should have it with a new slide in it?
2) for the moment I use the so called new joint, and was taking the slider out of my old, to build it into the new joint.
Also there was a breakage in the inner-slider, it seems. See photo. Is this slider seperate for sale, or always included in the joint normally?
best regards,Rudy
