Author Topic: Table for aluminium sealing washers.  (Read 2442 times)
rutger kohler
« on: April 08, 2014, 07:54:36 »
I have just had my oil filter and block, petrol pressure regulator, and petrol filter bodies bead blasted etc.  I have also had the hoses and pipes around these gold passivated (coated).  In doing so I have had to replace all the aluminium sealing washers.  It has been a bit of a job measuring these and replacing them so I have made up a Table in Word (attached) which may save others some time. If it is deemed worthwhile perhaps someone might put the Table in the manual?
« Last Edit: April 08, 2014, 09:05:38 by 280SL71 »
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
230slhouston
Re: Table for aluminium sealing washers.
« Reply #1 on: April 09, 2014, 00:56:07 »
Thanks for the info.
Do you have pics to share....before and after? I spoke to someone today about the same.
MBP
rutger kohler
« Reply #2 on: April 10, 2014, 05:57:04 »
Hi MBP I am holidaying in Sydney Australia for a month but when I get back to NZ I will take some before and after photos  if you like.  Andy Baker lent me a spare set of these so I could re-furbish them and leave mine on until I am ready to swap over.
1972 280SE 3.5 auto
