Author Topic: Instruments repair  (Read 4068 times)
dante53
Instruments repair
« on: April 11, 2014, 10:30:02 »
I found theese here
http://stores.ebay.it/Klassik-Armaturen-Todt
Not cheap but very good pieces
dante53
Re: Instruments repair
« Reply #1 on: April 11, 2014, 14:52:37 »
I forgot to explain that the brass pinion will replace the broken plastic one that did not allow me to reset the tripmeter
Flyair
« Reply #2 on: April 15, 2014, 21:10:26 »
I looked at the linked page and found out that the same item is listed by this seller several times, but always at a slightly different price, from 72 to 95 Euro + shipping costs.
FYI:
Checked also the SLS site and found the same item at an even lower price, just above 65 Euro.
http://www.sls-hh-shop.de/en/230-280SL-W113/54-Elektrical-Equipment-at-Body/54-a-Instruments/Rbbr-housing-speedometer-Rbbr-housing-speedometer.html
Long life to internet checks :)
Stan
2011 SL550 AMG
2011 GL
2015 GLA
andyburns
« Reply #3 on: April 16, 2014, 04:48:25 »
Can any of you tell me if these rubber covers were standard equipment on the early 230.  My car did not have these.  The instrument cases were in almost perfect condition with no signs of corrosion.  I am assuming the purpose of these is to keep moisture off the instruments if the windscreen is leaking or condensation from the foot wells get up behind the dash?  Otherwise I am at a loss to understand why you would want to 'condom' a surface that is unlikely to ever come into any sort of mechanical abuse.
1963 230sl
1967 250s w108
1969 BMW 2002
2007 Mitsubishi i car
dante53
« Reply #4 on: April 16, 2014, 06:20:26 »
Flyair, I searched a lot on SLS but evidently not enough because I missed it.
Andy, the rubber boots are supposed to avoid dirt and dust entering the instruments' housings and the backside of the glasses. The other function is to diffuse the light from instrument light bulbs
