Author Topic: Exterior Door Trim - Chrome Strip at top of Door  (Read 5215 times)
KW-BYBEE
  • USA, AZ, Phoenix
  • On her way to her new home!!
« on: April 15, 2014, 00:04:05 »
Can anyone tell me how to reinstall the piece of chrome at the top of the door next to the window?  I have new clips but have no idea how to clip the chrome onto the clips…..help!  I have looked in tech area and can't find any specific guidance
Kyle Bybee
Kent Island, MD
1967 250SL, 5 speed
Body Color: 571 Top: 040
Jordan
  • Canada, ON, Jordan
Re: Exterior Door Trim - Chrome Strip at top of Door
« Reply #1 on: April 15, 2014, 01:01:46 »
Kyle, I removed mine a few months ago to replace the window felt strips.  If memory serves the clips that hold the felt in place are the same ones that hold the chrome strip.  The clip fits over a ridge along the top of the door frame and on the inside you fasten the felt strip and the other side you slide in the chrome strip.  Hopefully I am remembering this correctly.
Marcus
66 230SL  Euro 4 speed
« Reply #2 on: April 15, 2014, 02:40:31 »
Kyle,
take a look at the photos here and let us know if you have additional questions:
http://www.sl113.org/forums/index.php?topic=8505
jpinet
« Reply #3 on: April 15, 2014, 04:05:03 »
Hi! I did this just last night! I had difficulty installing the chrome once the clips were attached to the door and the furry strip. Here's what worked for me.
First, the new clips were way too tight to fit over my door edge. I opened them up slightly with a chisel, inserting it in the central groove and tapping it in, on my workbench of course.  The clip has a large groove in the middle and one 'clip on each side. The short 'clip' goes on the outside. The short side attaches to the inside upper part of your chrome trim. There's kind of a channel there, with a bottom ledge and a top one. Clips attach to the top one. Try them on your chrome trim before you install them on the door. If it's really hard to get them to bite on the chrome strip, open them up a bit with a chisel and a hammer. Not too much, otherwise the clip won't hold the chrome strip. If you open it up too much, smack it gently with a hammer and try the fit again.
Now here's the trick: first, press your clips onto your door edge, making sure you have the short 'clip' outside. You can use 4 or 5 clips per door. I have 4 one door and 5 on the other, because I had 9 in all, and both sides hold fine. Make sure your clips go down as far as possible, otherwise, if one is higher, everything will be out of whack. You can 'gently' tap them in place with a small hammer.
Once all your clips are installed, press your furry strip in place on the long 'clips' which are now inside your glass opening. Be careful not to bend your strip, and get it in equally on the clips by pressing down equally along your furry strip. Remember to put the 'fur' part on the glass side.
Once you've done this, place your chrome strip on the exterior 'clips' and press on the strip to get the 'clips to bite into it. Remember, the clips are bitting into the top part of the interior 'track' inside your chrome strip. The strip lays down at an angle, so you kind of push outwards. You may have to use some strong pressure to get it in. Watch that the ends of your door rubbers fit inside the spaces at both ends of your chrome strip. If rubber gets in the way, it will prevent you from pushing in the chrome strip unto it's clips.
WARNING! If you're tempted to use a hammer, even a soft one to 'help' you get your chrome strip in place, remember that your door is made of aluminium and is not that solid, especially at the extremities. It will cave in. Ask me how I know... Good strong hand pressure should get your chrome strip in place and you'll feel it fit in place. Look to make sure your chrome strip is aligned with the exterior 'clips' and that you,re not skipping one. If so, you'll have to pull your strip off and start over.
That's about as much as I can tell you. The secret is really to make sure the clips fit nice and tight, but not too much both on the door panel and on the chrome strip BEFORE installing it in the door. I undid my clips, chrome strip and furry strip 2 times before I understood that! Ask me if you need more details.
As I read your post again I notice you own a 250SL. My description is for a 1965 230Sl and I know MB changed the clips at one point. Don't know what clips you have. Photos available on previous post by 66andBlue where you see the difference
« Last Edit: April 15, 2014, 04:14:26 by jpinet »
KW-BYBEE
  • USA, AZ, Phoenix
« Reply #4 on: April 15, 2014, 22:15:10 »
Alfred,
Thanks for the information.  My question is, do you install clips #2 to the chrome strip first and then attach to the door or attaché the clips and then somehow snap the chrome strip on the clips?
Kyle
Kyle Bybee
Kent Island, MD
1967 250SL, 5 speed
georgem
« Reply #5 on: April 16, 2014, 07:33:40 »
And for the belts and braces guys out there, once you have followed all the above instructions, a couple of large dobs of SIKAFLEX on the chrome trim before it is clipped in will keep it safely in place.
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
« Reply #6 on: April 16, 2014, 15:55:50 »
Kyle,
as I wrote in the linked topic I decided not to install #2 since this clip was eliminated in later model year 280SL cars and I assume is not necessary. But if you use, then follow Naj's advice and put it on the trim first and not the door.
KW-BYBEE
  • USA, AZ, Phoenix
« Reply #7 on: April 19, 2014, 12:17:18 »
Thanks to all for the help!!  Much appreciated.
Kyle Bybee
Kent Island, MD
1967 250SL, 5 speed
