Author Topic: Under dash insulation boards  (Read 3171 times)
« on: August 15, 2004, 14:12:23 »
I have received the 3 piece under dash boards and need help for installing the left (drivers side) piece. I can't seem to fit it & tried all different postions. My '63 230SL is std. 4 speed.  Wonder if I need to cut slits for the cutch and/or brake pedals? If anyone out there has a PIC or could make one I would appreciate it very much!!
Paul,
mulrik
Re: Under dash insulation boards
« Reply #1 on: August 16, 2004, 02:11:32 »
Paul
I had the same problem when I got my insulation pads from SLS in Hamburg. I simply cut it to fit. It can be tricky to figure out how it fits, but eventually you will figure out which is the right way. Remember that you can't see the pad unless you dive into it, so unless you are into concourse shows you'll be fine.
Ulrik
