Author Topic: 250 sl wiper blades  (Read 17367 times)
billhon
250 sl wiper blades
« on: April 22, 2014, 02:12:01 »
Replacement filler blades are Only $ 76.00 each through Mercedes!!!  After market replacements seem to be black which is not original silver. Any ideas?
Flyair
Re: 250 sl wiper blades
« Reply #1 on: April 22, 2014, 05:10:51 »
I am buying the vipers from a local supplier take off the rubbers and and replace them manually in my original Bosh silver wipers
« Last Edit: April 26, 2014, 14:44:09 by Flyair »
Stan
2011 SL550 AMG
2011 GL
2015 GLA
mnahon
  • Canada, QC, Montreal
« Reply #2 on: April 24, 2014, 02:27:57 »
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
Flyair
« Reply #3 on: April 24, 2014, 07:56:23 »
Meyer
I agree that the supplier Rubirossa is an excellent source. I bought a few things from him in the past, and it was without any problem. The wipers he sells do the job, but they are a bit larger, which gives them a look that is somewhat less slender like the Bosch ones
Stan
2011 SL550 AMG
2011 GL
2015 GLA
« Reply #4 on: April 26, 2014, 05:03:40 »
Just replace the rubber inserts. Years ago you could just order the rubber from Bosch.
« Reply #5 on: April 26, 2014, 06:49:22 »
Yes, just replacing the rubber inserts is the way to go but I see lots of cars that have black wipers and the owners don't realise that they should be silver. It's one of my cheap tricks to impress them!
Flyair
« Reply #6 on: April 26, 2014, 14:46:30 »
Stick,
same here... seeing things like black vipers on Pagodas make me think that a little gesture would make a great change, but then same goes for cap fillers, antennas, and radios.
Stan
2011 SL550 AMG
2011 GL
2015 GLA
billhon
« Reply #7 on: May 11, 2014, 00:48:44 »
Cool, what info do I need to order the wipers you suggest?  Thanks much!
billhon
« Reply #8 on: May 11, 2014, 00:50:03 »
Thanks, I ordered 2 sets.
  • USA, WI, Mequon
« Reply #9 on: September 28, 2015, 14:38:13 »
I discovered while cleaning my windshield, that my early 250 SL wiper blades were shot and I set about to replace them.  $75/each for a refill from Bud's Benz?!?  Well, that wasn't about to happen.  I checked some previous threads here (couldn't post on the more relevant one, no reply button) and saw that the 47-600 refill from Trico was recommended.  That's 6mm wide.  My arms and Bosch blades (what holds the refill) are original.  The claw has an interior width of 9.5 mm, no way a 6mm refill was going to work, as were all the wipers I saw at auto stores (would just pull the refill out), too narrow.  Through online research, I found that Trico makes a 47-800, an 8mm refill.  I could find no larger.  So, I found the one local store here that had them in stock, $8.99 for the pair, I don't know 26" long?  They have the snap off steel inserts.  Picked up the pair and checked the fit.  Obviously, it was narrower than my claw, but that was easily remedied by slightly squeezing the claws to match the refill.  Then, cut (not snapped - snaps too long) the steel inserts to size (a touch longer than the stock ones because of play in the retaining clip of the new steel inserts), cut the rubber refill and slide into the blade.  Perfect!  Original blade, new refills.  Only clue, the refill retaining mechanism on the steel stiffeners rather than an indentation in the refill rubber for the claw.  For $141 difference for a maintenance part, that's fine with me.  Added bonus, the refills are so long, I only had to use one for the two 12" blades.  I have an extra set ready to go, 4 refills for $9!  Take that Bud's and Mercedes.
mnahon
« Reply #10 on: October 03, 2015, 03:29:56 »
Hi John,
I recently went through a very similar exercise, but for 280SL Bosch wiper blades. Everything you say holds for those, except for the Trico part number. For those blades, the Trico 47-700 are the right fit. This model is for 7 mm trapezoidal claws. I have some pictures below. I went through the same steps as you to cut them to size.
Meyer
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
  • USA, WI, Mequon
« Reply #11 on: October 04, 2015, 00:32:09 »
your claws must be narrower than mine.  You have a 280 SL and I have an early 250 SL.
« Reply #12 on: October 04, 2015, 20:03:24 »
Bend them in a little bit.
  • USA, WI, Mequon
« Reply #13 on: October 05, 2015, 12:05:29 »
I did, see my post above (4 posts), I used the 8mm width (widest I could find), not the 7mm width the 280 SL poster mentions.  The point I was making is that earlier 113s may have wider wiper blade claws.
mnahon
« Reply #14 on: October 05, 2015, 16:37:23 »
John, I think you're right, and I think another difference is the claws on the earlier blades need a square section refill (Trico 47-600 and 47-800 are both square); but the later blades need a trapezoidal section refill (47-700 is trapezoidal).
Meyer
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
