Author Topic: Rear Axle Suspension Carrier Clunk Noise  (Read 7658 times)
ericlee
« on: April 23, 2014, 18:38:48 »
I have a 68 280SL.  I have clunk noises at the rear of the car sometimes.  I found the rear part of axel suspension carrier dropped relative to front part and the two pipes contact each other. the rubber bushing is gone where they contact.  Is it eary to replace a new rubber bushing? Do I have to drop the rear axle to do the repair?  I think I maybe able to handle it if I do not need to drop of the axle.  I recently changed the bushing near the center inside the trunk, I do not know if that caused this problem or not.
Thank you for any help!
Eric
mbzse
Re: Rear Axle Suspension Carrier Clunk Noise
« Reply #1 on: April 24, 2014, 18:30:25 »
Quote from: eric
.../...axel suspension carrier.../... Is it eary to replace a new rubber bushing?
Some info in this Forum thread, also there are links to other useful Forum threads there
http://www.sl113.org/forums/index.php?topic=19920.msg140662#msg140662
/Hans in Sweden
« Last Edit: April 24, 2014, 18:42:06 by mbzse »
/Hans S
ericlee
« Reply #2 on: April 25, 2014, 23:12:33 »
thanks, can I replace the rubber bushings without drop the axle?
GGR
  • USA, DC, Washington
« Reply #3 on: April 26, 2014, 14:32:14 »
It can be done, but it may not be a good idea. If that mount is worn is that fashion, your trail arm bushings may also need replacing. That's also a good time to replace seals and check/adjust backlash and replace the center rubber boot. There are also sleeves that may need replacement at the right wheel arm pivot points. Finally, when you replace that center mount, you need to adjust the position of the vertical arm, and it's easier done with the axle out of the car. It may look daunting to drop the entire rear axle, but it is in fact easier to work on the axle out of the car rather than fighting with two half axles dangling under the car.
« Last Edit: April 26, 2014, 14:38:51 by GGR »
ericlee
« Reply #4 on: April 27, 2014, 22:47:16 »
what is the reason of two tubes not concentric?  what part should I adjust?
GGR
« Reply #5 on: April 27, 2014, 23:12:51 »
They are not concentric because the rubber in between them has worn out.
« Last Edit: April 27, 2014, 23:39:54 by GGR »
George Des
« Reply #6 on: April 27, 2014, 23:20:23 »
I' ve redone two rear axles and can tell you there is no way I would try to do this job with the axles on the car!
jameshoward
« Reply #7 on: April 28, 2014, 17:50:46 »
+1; what he said!
James Howard
1966 LHD 230SL
ericlee
« Reply #8 on: April 30, 2014, 23:47:59 »
can I delay repair of this bushing?  will continuing driving as it is damage other parts?
thanks
garymand
« Reply #9 on: May 01, 2014, 04:13:53 »
Just metal to metal.  The part is $100.
