Author Topic: King Pin Renewal  (Read 3706 times)
Rolcan
King Pin Renewal
« on: May 03, 2014, 16:25:25 »
Hi All
I'm renewing the steering in 64 230sl and am having trouble removing the brass inserts in the body of the steering knuckle.  Are we to use a drift (correct size socket) to remove these sleeves, or do I need to take it to a machine shop and have them press the sleeves out.  Any suggestions would be welcome.
Cheers
Rolcan
Re: King Pin Renewal
« Reply #1 on: May 04, 2014, 03:29:58 »
Hello Rolcan,
The new bushings will have to be reamed to fit the king pins after they are pressed into place.
« Last Edit: May 04, 2014, 12:32:24 by ja17 »
GGR
  • USA, DC, Washington
« Reply #2 on: May 04, 2014, 11:18:57 »
I did that a while ago, so I don't remember for sure. I think I used a metal saw. Put the blade inside, reassemble the saw and cut both bushings at the same time. They may come out easily once you cut one side. If not, start again turning the assembly by 180 degrees.
You will also be able to press the new ones in place though you want to be careful not the damage them. Putting the new bushings in the freezer and heating the knuckle before assembly may help. As Joes said, you have good chances they will need to be rimmed. They may fit on the kingpin out of the knucle, but once pressed in there the pin won't fit anymore.
Rolcan
« Reply #3 on: May 05, 2014, 14:11:36 »
Thanks for the quick replies, I'll give the saw idea a try, worried I may score the inside of the knuckle, go slow I guess.
Thanks all
Greg
« Reply #4 on: May 06, 2014, 22:05:48 »
I have changed mine and used this method. Worked like a charm!!
http://www.youtube.com/watch?v=77UXeqlK6nY
Good Luck!
Rolcan
« Reply #5 on: May 07, 2014, 14:10:21 »
Thank you   that is exactly what I needed, great tip, that's why I love this site, all the helpful people.
Rolcan
