One can swap wires and move plugs and injectors around to narrow down skip problems, but after all is said and done, the best test before any is the compression test.. Once compression is eastablished , then you know what you are working with .
The best is testing compression specs and compression leak-down for each jug..On a leakdown test, you will know if your valves are leaking, are too tight , and which ones ..etc..This test will also give the Tech an idea of overall engine condition ..
Then start your swapping..
Another good tool for these old ignition vehicles is an ignition scope .. I see them on ebay for $40-$50 and once you have one , you will wonder why it took so long to get one
Between the compression test and ignition scope wave forms , you can diagnose all..
and , lastly , get yourself a nice , big vac gauge .. great for playing around with those IP adjustments...
..this is not to say that the plug/wire/injector swappings are not a good DIY tecnique. We use them all the time ...but for perfection sake , with a couple of standard test tools, you can make these 113s singgggggggggggg......
