Malc,
Thanks for the advice, it's what I expected but didn't want to hear.
I know I need to do valve work as the car burns oil out the exhaust (blue smoke). Also, I know the bottom end bearings are worn as I had the oil pan off once and removed the bottom half of the front two bearings and they were worn/scored. It would not suprise me if the cylinders were a little oval. Milage on the car is unknown, but the timing chain that was removed last year was not a factory original chain. I'm assuming it's got about 230,000 miles (368,000 km) on it since this is (at least) the second replacement chain and they last about 100,000 miles each. The Euro odometer reads 68,000 km right now, so that also was an input to my guess on the milage.
I'm trying to hold off on a major engine overhaul as long as I can because once I start that, then I'll want to do other things:
- refurbish automatic transmission
- rebalance drive shaft, inspect for worn parts
- replace leaking seal in differential
- refurbish rear axle seals and bearings
- replace full exhaust system
So, should I leave it parked, drive it like it is, or are there some more simple things I can do to improve the health of my engine compression?
1966 230SL, Euro, Auto, Leather, both tops
