Author Topic: what is this part af the auto trasmision??  (Read 3106 times)
erickmarciano
  • Canada, Quebec, montreal
« on: May 16, 2014, 15:49:42 »
Hi guys
what is the function of this is 22mm locknut with a 10mm adjustment bolt?
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Tom Colitt
Re: what is this part af the auto trasmision??
« Reply #1 on: May 16, 2014, 18:15:05 »
That is the adjustment for one of the brake bands. The brake bands do wear with time, to the point where there is even a longer internal pin available to compensate for this wear. The BBB gives you the adjustment procedure and specifications.
« Reply #2 on: May 17, 2014, 03:51:38 »
This is a reverse band adjustment.  If your reverse is working ok, just leave it alone.  Make sure that the 22m lock nut is tight.  Otherwise, to adjust, loosen the 22m nut move the 10mm in until just snug, then back it off 1 3/4 turns and lock it there.
