James,
Any luck with your clunk?
Red,
I don't think your idle & cylinder miss problem could be associated to a kickdown switch or 3-position solenoid. If your automatic shift lever needs pushed to 3rd in order to engage 4th (drive), then it's most likely the plastic shifter bushings. Search this forum for "shift bushing" and read to your heart's content. Finally, if you don't have any kickdown function in your automatic transmission, that would be related to the kickdown switch under the gas pedal and/or the 3-position solenoid on the transmission. Again, search this forum for these key words and read how others have done troubleshooting and repairs on these items.
1966 230SL, Euro, Auto, Leather, both tops
