Author Topic: How to remove a wheel shaft?  (Read 3630 times)
GGR
  • USA, DC, Washington
« on: May 21, 2014, 22:08:54 »
Hi all,
I need to pull the left rear wheel shaft to check on the wheel bearing. Up to know, I removed the shafts while the axle was apart so it was just a matter of pushing them out from the other end. I don't have a slide hammer, so I was wondering if there is a trick to remove them without it?
Thanks!
« Last Edit: May 21, 2014, 22:15:43 by GGR »
jameshoward
Re: How to remove a wheel shaft?
« Reply #1 on: May 21, 2014, 22:41:27 »
http://www.sl113.org/forums/index.php?topic=4487.0
Quite easy. You will need bolts that fit the axle half (have found that certain Ford head bolts are perfect) and some angle iron. And a very big hammer.
James Howard
1966 LHD 230SL
GGR
« Reply #2 on: May 21, 2014, 22:58:59 »
Thanks James, that's great!
