Author Topic: Strange spark plug fail M128  (Read 2765 times)
Micker747
« on: May 24, 2014, 00:22:01 »
I'm experiencing a strange spark plug failure on cylinder 3, plugs, cables, coil etc are all new oem.
The engine starts on 5 cylinders and number 3 does not ignite. If I then clean the spark plug with brake cleaner, it will run on all 6!
As soon as the engine cools down again, it will run on 5 cylinders. I can keep repeating this, but I'd rather fix the problem..
The engine runs normal and does not smoke or use much oil. Could it be oil seeping thru a valve stem seal or a loose valve guide, soaking the plug?
Regards
Michael
Re: Strange spark plug fail M128
« Reply #1 on: May 24, 2014, 04:22:43 »
If so, it will be the intake guide which is the problem.  Start off checking the compression on all six. Since it could be an injector, move it to a different cylinder and see if the problem moves.
Micker747
« Reply #2 on: May 24, 2014, 08:21:27 »
Thank you,
Is it possible to change the valve guide seals without  removing the cylinder head?
Regards
« Reply #3 on: May 25, 2014, 05:19:38 »
Yes but if the guides are worn, the new seals will jump off or will not last.
