Author Topic: trim removal  (Read 2902 times)
bob66542
trim removal
« on: August 20, 2004, 08:03:34 »
how is the beltline trim removed? i have the inner front fender splash plate removed, and it looks like i have to pry? out the black rubber door protector strip to access screws that hold the chrome trim to the body. is this correct? i dont want to damage any trim removing it. thanks,-bob
65 SL 230 4-sp. purchase 12-08-03
Re: trim removal
« Reply #1 on: August 20, 2004, 08:30:14 »
Yes, it's that simple. The aluminum trim for a 280SL beneath that is even easier -- it just snaps into place once you line it up.
Re: trim removal
« Reply #2 on: August 20, 2004, 08:33:39 »
I thought the chrom trim was rivetted ??
Is it easy to remove the splash plate ?  What would I need to get before I attempt to do it.........seals....bolts ??
'03 CLK Kompressor
Re: trim removal
« Reply #3 on: August 24, 2004, 10:29:46 »
I think they were originally held on with screws, but riviting is probably a common practice for the body shop guys.  My car has a mix of screws and rivits.
