Author Topic: settings for tracking and caster camber?  (Read 4265 times)
« on: August 20, 2004, 15:16:00 »
Hi all,
 Does anyone know the setting for caster camber and tracking as mine
is pulling to left a bit and can anyone tell me what a thing like a
silver spark plug socket in between the front right coil spring acts for I was told it had somthing to do with cars sent to the U.S depending
on what side of the road they were on.
Pagoda red.
red kelly
Re: settings for tracking and caster camber?
« Reply #1 on: August 22, 2004, 12:11:16 »
According to the 1969 Technical data book:
For 230/250/280SL:
Front camber: car in curb condition (full fuel, full oil, spare) +0 deg 10 sec (+ 20 sec). under test load 0 deg +20sec
Toe in (rolled) (in mm) 2 +/- 1, or 0 deg 20sec +/- 10 sec
Caster with mech steer - 3 deg 30 sec +/- 15 sec
       with pwr steer - 4 deg +/- 15 sec
Kingpin inclination 5 deg 30 sec
Rear toe in (rolled) (in mm) 0 +/- 2 or 0 deg +/- 20 sec.
Rear camber +1 deg 30 sec, +/- 30 sec.
« Reply #2 on: August 22, 2004, 14:06:10 »
Thanks Jonny,
 Thats great info, very greatful.
Red Kelly
red kelly
« Reply #3 on: August 24, 2004, 11:00:11 »
Originally posted by pagoda red
.... can anyone tell me what a thing like a
silver spark plug socket in between the front right coil spring acts for ....
Red,
Usually one thing is between two other things.  This thing that is like a spark plug socket is between the front right coil spring and what else?  In what part is this socket located?
« Reply #4 on: August 24, 2004, 13:16:27 »
I think you will find that to be a spring helper..
 They are inserted between the coils and then turned with a 1/2 drive socket wrench/breaker bar a 1/4 turn to wedge them in.
 They are not factory and can be bought in any auto parts store.
 The better ones are rubber..
A cheap out for a sagging spring
« Reply #5 on: August 24, 2004, 17:13:57 »
What are some intelligent questions to ask an alignment shop before getting work done on a W113?
« Last Edit: August 24, 2004, 17:14:32 by Bob G »
