Author Topic: Auto trans not engaging fully on my friends car. What can this be?  (Read 2764 times)
erickmarciano
  • Canada, Quebec, montreal
Hi guys my friend just finished his 5 year restoration.
When you step on the gas the car does not move as much as it should like it is slipping
Trying to help him out.are there adjustments in the clutch bands?
If so where and how.car shifts late and hard
The modulator is now at the minimum pressure Setting.
Thanks for your help
Erick
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Rolf-Dieter ✝︎
  • Canada, ON, London
Have you read thru this section?
---> http://www.sl113.org/wiki/Automatic/Start#RoughShifting
I don't know if you can access this area of our forum since you are not a full member ... Anyway give it a try
Good luck
GGR
  • USA, DC, Washington
The trans may be low on ATF.
