Author Topic: "Starla" brand exhaust? Good Quality?  (Read 8416 times)
« on: August 24, 2004, 13:16:27 »
Hi, my exhaust is shot and needs to be replaced, all of it. There is an EBAY seller who is selling a complete exhaust at a very good price.  Has anyone purchased the Starla brand, and happy with the fit and quality?  Thanks!
Re: "Starla" brand exhaust? Good Quality?
« Reply #1 on: August 24, 2004, 13:28:25 »
I have a Time Valve stainless steel exhaust. I am very happy with it.  I have not heard of the Starla but have heard of Borla.
« Reply #2 on: August 24, 2004, 13:59:08 »
What a coincidence because today I was going to post regarding exhaust systems. Mine is also shot, and the muffler shop said I should keep the engine pipes and replace the rest. What are your thoughts, I thought it best to replace everything. I was also recommended a Timevalve Stainless Steel version at $640. + labor (the muffler shop quoted $780 including labor for the steel version from another company. DOES the Timevalve have the same sound as the stock? I do not want a noisier unit??
« Reply #3 on: August 24, 2004, 13:59:32 »
I saw that system on ebay too. All I can tell you is that, for what it's worth, I have found that seller to be a very ethical individual.
« Reply #4 on: August 24, 2004, 14:02:52 »
I have a Timevalve system and have found it to be slightly louder than the OEM unit on my last Pagoda. It's a pleasant sound, but definitely a different, slightly "tinnier" sound.
« Reply #5 on: August 24, 2004, 14:08:53 »
I think the Timevalve exhaust sort of gives it a "throaty" sound.
Ricardo
« Reply #6 on: August 24, 2004, 20:28:29 »
I have OEM mufflers but I used a Starla headpipe and intermediate pipes....the intermediates were fine, but the headpipe required some adjusting, the clearance and angle were off and to get a good fit took some heat and bending...no problems since. I have heard that some owners have found the flange bolts at the manifold/headpipe connection would loosen, though I'm not sure if they were Starla headpipes.
Ricardo
« Reply #7 on: August 26, 2004, 16:38:17 »
Any others have experience with Starla, or another brand for a alternative to the stainless timevalve?
« Reply #8 on: August 26, 2004, 16:51:13 »
I think the gold standard in OE exhausts is Eberspacher. Far superior to Bosal or Ansa in terms of the gauge of the steel. Much heavier and more durable.
« Last Edit: August 26, 2004, 16:51:57 by Douglas »
TA250SL
« Reply #9 on: August 26, 2004, 21:24:49 »
Which vendors sell Eberspacher exhaust components?  I have not seen them advertised anywhere.
« Reply #10 on: August 26, 2004, 21:48:38 »
If you order from a Mercedes dealer, they should supply Eberspacher.
Malc
« Reply #11 on: August 27, 2004, 05:16:06 »
Speaking of exhuasts I remember reading an article about "reproduction" ones often have the centre crossover / balance part missing and this can cut up to 4 mile per gallon (UK size) off your economy.
However prices are "horrible" in the UK
Malc
