Author Topic: Power steering pump  (Read 4971 times)
gnj588d
Power steering pump
« on: July 08, 2014, 15:43:29 »
My friends 280sl power steering pump siezed on the way back from classic Le Mans yesterday,can anyone tell me if these pumps are used on any other Mercs as he was told they are no longer available,there is plenty of oil in the reseviour.Any advise would be much appreciated.Thanks. Mike. :'(
Fintail
Re: Power steering pump
« Reply #1 on: July 08, 2014, 18:41:36 »
Hi Mike
Have a spare give me a call 07891070248
All the Best John Furber from Loggerheads
« Reply #2 on: July 09, 2014, 13:13:38 »
Mike, these pumps are used on most of the Mercedes four and six cylinder sedans, in the late sixties and early seventies. The earliest version (early sixties) will also work, but the shaft for the pulley on the pump is straight, whereas the pump after 1965 had a tapered shaft.
Larry & Norma
« Reply #3 on: July 09, 2014, 13:56:40 »
As a matter of interest the pumps were made by Vickers of the UK.
They have the only non metric bolts in the car :o
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
gnj588d
« Reply #4 on: July 09, 2014, 14:12:09 »
Thanks everyone very interesting info. My friend got sorted.Cheers Mike.
« Reply #5 on: July 10, 2014, 08:12:00 »
You are so correct Larry, the casual observer may not realize that the bolts heads are actually 9/16", since a 14mm wrench also fits just fine. However the threads on these bolts are not metric. One should be careful not to loose track of the spacer between the pump and the bracket at the rear.
mbzse
« Reply #6 on: July 10, 2014, 09:46:09 »
Quote from: Larry & Norma
Well, yes almost. I had the same assumption as you, Larry. However, this is a different Vickers, an American pump company.
See http://www.sl113.org/forums/index.php?topic=12850.0   reply No 6 and 7.
/hans in Sweden
/Hans S
Larry & Norma
« Reply #7 on: July 10, 2014, 13:52:34 »
From memory the thread of the mounting bolt is 3/8 UNF I believe.
2023 Ioniq6
2005 C230
