Author Topic: W110 front subframe mounts question  (Read 4203 times)
GGR
  • USA, DC, Washington
« on: July 11, 2014, 18:38:22 »
My wife's W110 230 front axle mounts are shot (the ones in between the top of the axle and the chassis rails).  I noted these W110 do not have that lateral strut (or guide rod, p/n 111 330 03 30) between the center rear of the front axle and the right chassis rail that is found on the 108/109/111/112/113 chassis. I also noted they have different subframe mounts. Does that mean these mounts are stiffer and take care of preventing lateral movments hence the absence of that guide rod?
I have good W108 type subframe mounts lying around. Does that mean that I'm going to end up with a lot of lateral movement if I fit them on the W110 in absence of that rod?
Thanks in advance for the help!
scoot
  • USA, CA, Altadena
Re: W110 front subframe mounts question
« Reply #1 on: July 11, 2014, 23:12:13 »
I have heard that the W110 subframe mounts are NLA and that you can't use the W108/W111/W113/everything else mounts.  You need to confirm that with the Heckeflosse community, try Vintage subforum on PeachParts or Benzworld and you will probably get an answer.
Scott Allen
'67 250 SL (early)
Altadena, California
