Author Topic: Slow blinker  (Read 4946 times)
gvillayandre
Slow blinker
« on: July 15, 2014, 11:25:12 »
I have a problem with indicator blinker.
When I conect left side they blink fast, when I conect right side they blink slow and when I conect hazard lights the four lights blink fast.
Any clue?
Thanks in advance.
ejboyd5
  • Southold, NY
Re: Slow blinker
« Reply #1 on: July 15, 2014, 11:31:37 »
Check the lamps (bulbs) installed in the system to assure that they are the proper size (wattage).  A power usage that is more or less than the designed normal will cause the flasher unit to operate at different rates.
scoot
  • USA, CA, Altadena
Re: Slow blinker
« Reply #2 on: July 15, 2014, 13:25:10 »
Fast blinking is indicative of a burnt out bulb, or replacement with LED bulbs.  Basically it isn't drawing enough current.
Post a picture of your blinker switch.
If it's like the one in a 1971 114, fast or slow blinking can also be indicative of the switch/relay being bad, in which case the solution is to replace the switch/relay.  Not sure if a 71 113 has the same switch/relay, as my car is a 1967, but I can tell you from a picture of the switch.
Scott Allen
'67 250 SL (early)
Altadena, California
jameshoward
Re: Slow blinker
« Reply #3 on: July 15, 2014, 18:21:05 »
James Howard
1966 LHD 230SL
gvillayandre
Re: Slow blinker
« Reply #4 on: July 15, 2014, 19:05:14 »
Thanks all!!
I will start with bulbs check.
Some more news tomorrow.
gvillayandre
Re: Slow blinker
« Reply #5 on: July 15, 2014, 19:18:47 »
Two more questions.
There are different blinker relays for indicators and hazard, or is the same can?
Correct bulb size in wats is 18w?
Thank you!!
Re: Slow blinker
« Reply #6 on: July 15, 2014, 22:09:54 »
It depends on the model. In 230SL the hazard/emergency flasher has its own flashing circuit separate from the turn signal flasher. On later 280SL cars they are combined.
Quote
Don't forget to consult the technical manual!  ;)  http://www.sl113.org/wiki/Electrical/TailLights
18W in 230SL and 21W in 280SL
Which model do you have??
gvillayandre
Re: Slow blinker
« Reply #7 on: July 16, 2014, 06:38:45 »
Mine is 1969 280sl.
Answers to my questions.
There are two blinkers one built in the hazard swicht and the other in aluminum can for indicators.
One of the bulbs was 21 watts.
Problem solved!!!
Thanks to all for your information.
