Author Topic: spark plugs wires  (Read 2922 times)
catjim813
spark plugs wires
« on: July 16, 2014, 15:15:32 »
Has any one tried the Bosch plug wires being sold by auto-haus in AZ  Is this the correct plug wires for ours cars price just seems to be good value.
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
Re: spark plugs wires
« Reply #1 on: July 16, 2014, 18:28:53 »
I had to purchase two Bosch wirw sets, because the #1 plug wire socket is at a 90 degree angle and is a resistor socket.  I used the #2 wire from second set to replace the #1 wire, to give it the correct look and to replace the resistor.
Robert Hyatt
Williamsburg, VA.
« Reply #2 on: July 16, 2014, 20:42:00 »
This Bosch set: https://www.autohausaz.com/search/product.aspx?sid=a3rbmt45rn302j55rxqajt55&partnumber=09023
is a very good value but it looks like the #1 wire has a 90 degree connector on the spark plug end (it should be straight), but if you have a 280SL then the connectors on the distributor end should all be 90 degree.
Read this: http://www.sl113.org/wiki/Electrical/SparkPlugWires
