Author Topic: Limited Slip Differential Oil - Special Oil?  (Read 4837 times)
kampala
  • USA, CA, Beach Cities
« on: July 19, 2014, 00:29:05 »
I am a little confused about the special oil for a Limited Slip Differential.  My local MB dealer could not advise on which oil to use so I got it from the classic center -- they said the correct oil for the LSD is part number A 001-989-33-03-12.
My local mechanic, who was going to change the diff oil for me as it's not easy without a proper lift, asked me to get the special oil and he'll do the change.  Admittedly he's not a specialist on these cars as he works on modern mercedes, however, when I showed him this oil, he wanted me to double check as he is surprised that the weight is so close to standard diff oil.  This mercedes oil is described as: Differential Oil; Hypoid Gear Oil; SAE 75W85.
Also I have read that this oil is a replacement for a no longer avail oil.
Can someone advise if I have the correct oil for a Limited Slip Diff?
Any help would be appreciated.
« Last Edit: July 19, 2014, 04:28:44 by kampala »
250sl - later - manual
280sl - 1971 - Auto - LSD
Re: Limited Slip Differential Oil - Special Oil?
« Reply #1 on: July 19, 2014, 08:48:36 »
I use veedol LS90
sandcrab59
  • USA, MA, Lunenburg
« Reply #2 on: July 20, 2014, 00:43:44 »
Ask JA17.
Joe  will know the correct oil.
Tom Mrowka
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
« Reply #3 on: July 20, 2014, 01:19:09 »
Dan C, Benz Dr also runs a LSD in his Pagoda so would be a good source of oil recommendation.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
kampala
« Reply #4 on: July 20, 2014, 15:32:32 »
Thanks all - appreciated.  Since I'm in California with the car, I can't seem to find the Veedol locally.
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #5 on: July 21, 2014, 03:24:11 »
After much discussion I went to the Mercedes shop and bought the LSD oil that they sell.  The part number seemed to be for a much newer car but the mechanics said it was the right stuff for my old girl.  Definitely not cheap though.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
