Author Topic: Needed: Bulb #s  (Read 3776 times)
vande17941
  • USA, CA, Irvine
Needed: Bulb #s
« on: July 31, 2014, 20:23:47 »
I've searched and searched everywhere I thought of... Does anybody have a list of all the bulb numbers and wattages for a 230 SL
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
Re: Needed: Bulb #s
« Reply #1 on: July 31, 2014, 20:34:15 »
.... appears you forgot to look into our technical manual right here:
http://www.sl113.org/wiki/Electrical/TailLights
http://www.sl113.org/wiki/Electrical/EuropeanLamp
and of course here: http://www.sl113.org/wiki/Documents/OwnerManual  Your owner manual lists all the bulbs that you can replace!  ;)
vande17941
  • USA, CA, Irvine
Re: Needed: Bulb #s
« Reply #2 on: July 31, 2014, 22:25:13 »
Thank you. However, I have looked at both pages of the technical manual you cited and I do not see bulb model numbers for a 230 SL USA car. Also, my user manual seems to show numbers which no longer exist or have been superseded.
If someone  lists the actual bulb numbers from, say, Sylvania, Phillips, GE ect that would be great.
Re: Needed: Bulb #s
« Reply #3 on: July 31, 2014, 23:25:45 »
Look at these 16 pages: http://www.authenticclassics.com/category-s/52.htm
and you should find what you need. If not send the owner an email and ask, he is a member here.
