Author Topic: engine starting problem  (Read 3188 times)
jtranter
« on: August 10, 2014, 15:33:24 »
When I first start my 280SL, everything works fine.  However, after I driven the car for a good while and turn it off, it will not restart.  If I wait a while and it cools down, it starts.  My mechanic replaced the starter, but the problem continues.  When I try to start the car after it has run in a while, I usually get a clicking sound; sometimes not.   Any suggestions, before I take it back to my mechanic?
Jack
ctaylor738
  • USA, VA, Falls Church
Re: engine starting problem
« Reply #1 on: August 10, 2014, 18:34:57 »
My starter list, with problem areas in CAPS.
1. If it's an automatic, try starting in N, plus have someone move the shifter while you try to start.  BAD NEUTRAL SWITCH
2. Check the battery ground at the frame and battery ends. BAD GROUND
3. Check the ground strap that runs from the bell housing to the firewall BAD GROUND
4. Check to see if you are getting current to Terminal 50 (small wire on the starter).  WORN IGNITION SWITCH
5. See how much voltage /resistance you have at the big lug on the starter.  CORROSION IN MAIN WIRE FROM BATTERY TO STARTER
Good luck,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #2 on: August 10, 2014, 22:58:13 »
I recommend you have a read thru Pagoda Notes ----> http://www.sl113.org/wiki/uploads/Restricted/PNv2i2.pdf
Also the following two issues on the Starting Tour.
« Reply #3 on: August 11, 2014, 12:15:29 »
Are you saying that the engine does not want to turn?
jtranter
« Reply #4 on: August 11, 2014, 19:30:36 »
Jack
