Author Topic: Soft top replacement  (Read 4235 times)
robertcedgar
« on: August 10, 2014, 16:17:34 »
I was wondering if anyone knew of a quality business in the Los Angeles area who would be able to replace my soft top canvas on my 71 280SL?  And what approximately, should I expect to pay for such a job?
Rob
Re: Soft top replacement
« Reply #1 on: August 10, 2014, 18:17:26 »
Check out German Auto Tops: http://www.germanautotops.com/ they also do installations.
You can also search for more info on GAT here and you'll find for example:
http://www.sl113.org/forums/index.php?topic=20008.msg141902#msg141902
robertcedgar
« Reply #2 on: August 11, 2014, 02:06:33 »
Thank you very much!
« Reply #3 on: August 11, 2014, 03:37:56 »
Rob,
show us a photo of the new top when it is done!  :)
robertcedgar
« Reply #4 on: August 11, 2014, 15:28:00 »
Will do...thanks again!
jedwards
« Reply #5 on: August 12, 2014, 00:18:57 »
Its quite an achievable and satisfying job to do it yourself, even for a first timer like me.  I had never done a soft top before, but ended up with something I am pretty happy with.
I bought my top from Topsandseats.com for $325.00. I read all the great advice on this forum and took my time and did it over a weekend.
Well worth trying.
The images here are after it has been stowed for over a month and just opened and put up to take these pics. It stretches out nicely once its warm.
robertcedgar
« Reply #6 on: August 12, 2014, 14:04:51 »
Jedwards,
Thank you very much.  I thought about doing it myself.  I am fairly mechanical but when I looked into doing it myself, I became a bit overwhelmed.  Was it fairly easy for you and which advice/instruction column did you follow?
Rob
