Author Topic: Wiring diagram for an early 280SL Automatic gearbox  (Read 4099 times)
Quin
« on: August 29, 2014, 11:51:57 »
When starting rebuilding my 280SL Automatic , I have taken out all the not original wires which were added all around ( to fuel pump , to coldstart valve and low temp sensor , to injection pump ) ,under the dashboard and in the motor compartment.
To rebuild and to re-connect all wires as original as possible , I'm looking for a wiring diagram  280SL with automatic gearbox .
thanks already in advance
Re: Wiring diagram for an early 280SL Automatic gearbox
« Reply #1 on: August 29, 2014, 12:06:38 »
If you look in the Tech Manual there are wiring diagrams for all the cars available to Fumm Members..  :o
http://www.sl113.org/wiki/Electrical/WiringDiagram
Using the search function, click on the Tech Manual then do the search on the left hand side for anything you need.  As a Full Member, you have total access to all parts of the Forum and Manual
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Quin
« Reply #2 on: August 31, 2014, 11:07:18 »
Thanks for the tip .
Indeed found back lot of information and I already could reconnect the fuel pump , the cold start relais and valve  .. I still some things to search and refurbish and with little bit of luck I will be able to start the engine end next weeK .  :)
« Reply #3 on: August 31, 2014, 11:41:52 »
And if you have any problems just ask the questions and I am sure members will jump in and try to answer them so that your Pagoda is back on the road.
Good luck with the engine start up.
