Author Topic: What pressure does the power steering recirclating valve lift at?  (Read 3526 times)
rutger kohler
I have replaced my high pressure hydraulic hose, on the power steering, using my refurbished
hose ends. I want to test the hose off the car before I fit it.  Have some original MB data sheets that suggest that the pressure should be between 55 and 65 bar (825 -975 psi) at 1000 RPM  but nothing on what the re-circulating valve opens up at.  Is this the pressure range that it opens up as well?
andyburns
Re: What pressure does the power steering recirclating valve lift at?
« Reply #1 on: September 05, 2014, 07:01:27 »
Rodger,  what did you do for the low pressure hose.    I am going to find some replacement hose for mine which is a bit dodgy.
1963 230sl
1967 250s w108
1969 BMW 2002
2007 Mitsubishi i car
rutger kohler
« Reply #2 on: September 05, 2014, 07:38:25 »
Hi Andy, Lloyd supplied me a piece, will look at it tomorrow.
cheers
Rodger K
