Author Topic: Correct Rotary AC Compressor?  (Read 2883 times)
vande17941
  • USA, CA, Irvine
« on: September 19, 2014, 18:18:39 »
I have a rotary compressor in my 230sl. I can read that the label says it's a Sanden...but the model number is illegible.  Does anybody have a model number that is a correct model number.
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
Rick
  • USA, NV, Gardnerville
Re: Correct Rotary AC Compressor?
« Reply #1 on: September 21, 2014, 21:21:22 »
Contact one of the suppliers for Sanden and they will be able to ID what you need.  You can also contact Vintage air or even Bud's Benz.   The Sanden SD8 was commonly used on these cars to replace the York, but you need to get the correct pulley and inlet/outlet configuration.  There are generic Sanden copy compressors out there but I would avoid those because you just don't know what you might be getting.
Baybear
  • USA, VA, Midlothian
« Reply #2 on: September 22, 2014, 17:20:08 »
I have a 1971 280sl with the Sanden compressor. The number is U 9285. It has a double pulley clutch but only one belt is used. It was installed in 1999.
Will
Will Milby
1970 300SEL 6.3, 1971 280SL, 1972 300SEL 4.5, 1972 Super Beetle, 1998 SL500, 2010 350 GLK, 2012 SLS AMG
