Author Topic: Fuel tank to fuel pump pipe bore  (Read 3139 times)
rob walker
« on: September 21, 2014, 16:19:53 »
Hi all,
Can anyone give me the inside bore of the fuel tank to fuel pump pipe.
I have just changed the pump out pipe, but the tank to pump looks a larger bore and I want to get the right pipe, before taking this off.
Thanks Rob
Re: Fuel tank to fuel pump pipe bore
« Reply #1 on: September 22, 2014, 01:31:16 »
The line going from the tank to the electric fuel pump is about 12 -13mm (1/2").  Low pressure fuel hose can be used here. Do not use coolant hose.
« Reply #2 on: September 22, 2014, 05:58:52 »
There are two different tank outlet sizes, 10 and 13 mm. See my thread on modified fuel pump.
rob walker
« Reply #3 on: September 24, 2014, 13:57:29 »
Thanks guys,
all done.
