Author Topic: Headlight relay location  (Read 3649 times)
awolff280sl
  • USA, FL, Sarasota
« on: September 25, 2014, 13:15:46 »
Question: where is the headlight relay located in a 1969 280SL? Thanks.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Re: Headlight relay location
« Reply #1 on: September 26, 2014, 12:18:49 »
No relay used afaik
Naj
  • USA, WI, Mequon
« Reply #2 on: September 26, 2014, 13:02:22 »
I installed one to take the load off my switch.
awolff280sl
  • USA, FL, Sarasota
« Reply #3 on: September 28, 2014, 16:39:14 »
John,
Did you want the relay for brighter than stock headlamps?
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
« Reply #4 on: October 06, 2014, 14:59:19 »
Quote
No relay used afaik
Naj
There is none from the factory ...
- as Naj alreay mentioned.
Eveything else is aftermarket.
Might be good and safer thing - but is aftermarket.
(still stock)
