I recently had the alternator warning light on my 250 SL illuminate, albeit dimly, on idle. Curiously it would illuminate like this after long driving. There are no start issues, with starter cranking as normal, but the only other electrical clue I noticed were the slight dimming/brightening of the driving lights at night whilst driving.
I tested the battery voltage, and to my surprise idle voltage read 15.5-15.7 (!) volts, and with the engine turned off 13.5 volts (?).
I suspected the voltage regulator, however substitution with another (old) unit left reading unchanged.
Does the problem lie solely with the alternator, and if so why would the circuit overcharge rather than not produce enough voltage? Has this excess voltage damaged the battery cells?
Car currently has original type Bosch 35Amp alternator.
Any help/advice much appreciated.
Charles
