Author Topic: Recessed Rotor Button Syndrome  (Read 4980 times)
ctaylor738
  • USA, VA, Falls Church
« on: September 30, 2014, 13:20:56 »
Uhhh, just when you think you have seen it all.
From a 250SL with less than 100 miles on a new 123 distributor.  Complaint was hard starting and miss above 3000 rpm.
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Re: Recessed Rotor Button Syndrome
« Reply #1 on: September 30, 2014, 13:44:04 »
Hello Chuck,
That's not so uncommon. The button can be broken off when the distributor cap is being "wrangled" in position. Be sure to go looking for the broken button. It will roll around in the distributor and can short out the ignition even after a new cap is installed. It can also jamb the centrifical advance mechanism.
GGR
  • USA, DC, Washington
« Reply #2 on: October 01, 2014, 00:14:37 »
I've seen that a couple of times. I always check it when I have the distributor cap off.
wjsvb ✝︎
  • USA, VA, Virginia Beach
« Reply #3 on: October 01, 2014, 02:29:28 »
Having been a marketer of ignition (and other auto) parts for the last 40 or so years, I can say that the problem is more common than it should be, particularly with aftermarket caps for Bosch applications.  It seems that there is a clinching operation in the assembly process which is often left incomplete, followed upon installation by...you guessed it!  Had to (still do) check each one.  Stretch the spring slightly to hold it in the tube. :'(  Once in the car, the contact button should be held in by the rotor contact/spring.  Jon
jon
67 250SL early
12 Jeep GC (gone but not missed)
69 300SEL 6.3 Euro project (gone but not forgotten)
81 280SL Euro 4spd
ctaylor738
« Reply #4 on: October 01, 2014, 15:51:32 »
Geez,
Guess I've been lucky and had a sheltered life.  It was a Bosch cap, though.
Cheers,
CT
Chuck Taylor
1963 230SL #00133
Falls Church VA
« Reply #5 on: October 01, 2014, 20:50:24 »
On a slight tangent but there are aircraft engines that use Bosch rotors and there have been several incidents of rotor failure caused by poor quality of replacement parts.
