Author Topic: 250SL MYSTERY PART...  (Read 4807 times)
PMO956F
« on: October 05, 2014, 09:01:54 »
Hi guys
Could anyone tell me which part this maybe , it was in the cad plating box with all the other bits  (all mixed together!) still rebuilding the car so im sure i will find out sooner or later
clue -   its not an engine or transmission internal
Any Help welcomed !
ps pic attached 7 years down the line !
« Last Edit: October 05, 2014, 09:23:15 by PMO956F »
andyburns
Re: 250SL MYSTERY PART...
« Reply #1 on: October 05, 2014, 09:09:31 »
It could be the rod that screws into the end of the clutch slave cylinder? Sure someone with better knowledge will chime in here.
1963 230sl
1967 250s w108
1969 BMW 2002
2007 Mitsubishi i car
PMO956F
« Reply #2 on: October 05, 2014, 09:18:46 »
thanks Andy , sorry should of mentioned its an auto !
andyburns
« Reply #3 on: October 05, 2014, 09:25:58 »
Ah, what about the rod the screws into the firewall on the inside that the accelerator pedal stop on?
1963 230sl
1967 250s w108
1969 BMW 2002
GGR
  • USA, DC, Washington
« Reply #4 on: October 05, 2014, 09:30:21 »
If you don't find what it is, ask the workshop who did the plating if someone complained he was missing a part. They often mix up stuff, and someone may be looking for it.
Is it metric?
PMO956F
« Reply #5 on: October 05, 2014, 11:43:26 »
thanks again , the floor was replaced so there is no bolt hole  and my pre resto my photos dont show the area im afraid
BTw yes its metric , and yes i guess it could be someone elses missing part , but i had it all plated 3 years ago so cant check.
Thanks again for your help
Dave H
  • United Kingdom, England, Durham
    • Dave H
« Reply #6 on: October 05, 2014, 15:08:49 »
Is it the cotter bolt off your rear diff ?
Does it have a taper on the other side ?
Mercedes 250SL    1967
Mercedes 250SLK  2014
Alfa Romeo 166 3.2 Ti
Fiat 500
andyburns
« Reply #7 on: October 05, 2014, 18:31:58 »
If you have replaced you floor you should have the hole that I am referring too. If you pin has that taper on the Dave is definitely nailed it.
1963 230sl
1967 250s w108
1969 BMW 2002
jameshoward
« Reply #8 on: October 05, 2014, 21:33:40 »
It is definitely the rear diff pin.
James Howard
1966 LHD 230SL
PMO956F
« Reply #9 on: October 07, 2014, 06:39:20 »
Thanks Andy
Yes you may have it ! it doesnt have tapers , so could be the part , thanks for the pic its very usefull, and also to the other members for helping too!
ctaylor738
  • USA, VA, Falls Church
« Reply #10 on: October 08, 2014, 13:26:06 »
This may be too much information, but for the true parts geek:
The PN for the accelerator stop is N 00084 0008220.  An N number means that it is a generic part specified in the DIN und Normteile book.  This number is in the book as a "cyl[inder] head screw" M8 x 50 mm, exactly as shown in the picture.
Good call, Andy.
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
