Author Topic: Which Lower Rear Panel is correct?  (Read 3672 times)
RobSirg
« on: October 05, 2014, 10:00:50 »
Guys,
In comparing my project car (1970 280SL) to my restored car (1969 280SL) I noticed that the lower rear panels are slightly different. The Project car tends to make a downturn (which I think matches the lower rear side panel) whereas my restored car curls under. (see below)
I'm fairly certain the project car has had repair work in the rear as I have non-matching tail lights.
My guess (and hope) is that the restored car is correct and the Project car is not. (IE: Lower rear panel should curl under and not finish with a small downturn towards the ground).
Appreciate your thoughts / comments :
Rob
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
mmizesko
  • USA, OH, New Albany
Re: Which Lower Rear Panel is correct?
« Reply #1 on: October 05, 2014, 12:12:03 »
Rob,
The 69 is correct.  It should curl under the car, with a couple of half moon cutouts for the drains.  If you need another, you can order a lower tail panel from K&K in Michigan here in the States ($250 or so), but you'll have to cut, weld, and paint.
Mike Mizesko
Columbus, OH
1970 280SL 291H Dark Olive
RobSirg
« Reply #2 on: October 05, 2014, 12:20:57 »
Thanks Mike,
That's what I thought. Yes, I did see that K&K have a half panel. The car will be stripped down soon - so I will see which way the panel shop wants to go with it - whether to weld a half panel or work with what I have.
Was wondering what those random looking half-moon cut outs were for. Thanks for the information.
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #3 on: October 05, 2014, 15:43:37 »
Yup, I just looked at my 280 SL, and the panel curves under, has the two cutouts, and a nice row of spot welds for the entire length. The spot welds will be the tricky part.
