Author Topic: early 230SL starter and alternator  (Read 3552 times)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« on: October 05, 2014, 18:48:00 »
I just ordered a remanufactured Bosch SR 59X starter and a remanufactured Bosch 35 amp alternator for my 64 230SL. Now that I've ordered them, I'm starting to wonder if I should have ordered them through Bud's or SLS..
Will the starter and alternator be simple bolt-ons or will I need to do some modifications to my wiring? Note that I have an early 230 with the four alternator terminals (vice a plug).
Reason I ask,,,I noticed a string from several years back regarding the Bosch SR 59X and changing/rewiring the ballast resistor (huh?). Wihat does the ballast have to do with the starter? thanks in advance for any reassurance regarding my order..thanks, Charles
Re: early 230SL starter and alternator
« Reply #1 on: October 06, 2014, 03:38:18 »
Chafles, the later  starter is definitely a plus. More power easier to find. The alternator is a bit more complex. The wiring changes from ring terminal connections to a plug connection.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #2 on: October 08, 2014, 15:17:26 »
ok, thanks Joe.
alchemist
  • USA, NY, GRAND ISLAND
« Reply #3 on: October 09, 2014, 02:41:24 »
I noticed that that regular auto stores such as Autozone and advanced Auto carry Alternators and starters for 230 and 280 SL. I was surprized to find an alternator for 280SL at advanced Auto with lifetime warranty for only $75. It came with the correct plugin fitting. Check these stores out.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #4 on: October 09, 2014, 19:25:32 »
yes, unfortunately, the auto parts stores I checked only had the later model alternators with a plug connection. I have an early 230 with four ring terminals (vice a plug) and I don't want to modify my wiring.  I decided to go with my original alternator and replace the brushes.  thanks, Charles
