Author Topic: Kingpin installation  (Read 4488 times)
Albert
« on: October 07, 2014, 21:08:53 »
Once I've installed the new bronze kingpin bushes will they require reaming?
If so any idea of the size?
I'd like to get all my tools ready for when the bearing carrier / stub axles are back from blasting
Regards
Al
DaveB
Re: Kingpin installation
« Reply #1 on: October 07, 2014, 21:36:15 »
Hi Albert - use the search, there's plenty of information on the site:
http://www.sl113.org/forums/index.php?topic=2187.0
DaveB
'65 US 230sl 4-speed, DB190
Dave H
  • United Kingdom, England, Durham
    • Dave H
« Reply #2 on: October 07, 2014, 22:12:59 »
Hi Al
Just done my king pins, adjustable reamer was from Tracy tools and arrived in 2 days.
Hardest part was removing the old bushes , put a length wise cut through each one with a hacksaw and drift them out.
The reaming part is easy, getting the right end float is a bugger,  several thickness,s of shim washers are provided as you will know.
Dave
Mercedes 250SL    1967
Mercedes 250SLK  2014
Alfa Romeo 166 3.2 Ti
Fiat 500
mbzse
« Reply #3 on: October 07, 2014, 22:34:20 »
Quote from: Dave H
.../...getting the right end float is a bugger,  several thickness,s of shim washers are provided as you will know
Dave, were you able to reach the suitable end float (0,05mm to 0,1mm max) with the washers provided in the repair kit(?) Or, did you manufacture new washers or machine the ones provided in kit?
/Hans in Sweden
/Hans S
Dave H
    • Dave H
« Reply #4 on: October 08, 2014, 10:32:43 »
Even the thinnest washer in my kit was too thick, i skimmed it against a broad file and then a wide emery board untill it gave me the end float i was happy with.
Each time i reassembled and torqued the bottom nut it would go tight, undo, take a bit more off and fit up/retorque again untill the carrier turns free.
I had to take it apart again and remove a bit more off the washer until it was right.
Took about four attempts , about an hour each side untill i was happy.
Keep measuring what you are taking off your washer each time with a digital micrometer and it will give you a good idea of your final end float.
0.05 to 0.10mm is only 2 to 4 thou so only a tiny amount of end float is required.
« Last Edit: October 08, 2014, 13:03:17 by Dave H »
Mercedes 250SL    1967
Fiat 500
Albert
« Reply #5 on: October 08, 2014, 21:06:55 »
Loads of info thanks
I'll check the machine shop at work before I purchase the one you suggest.
I also have the option of a large oven & liquid nitrogen for installing the bushes.
This task shouldn't be so bad
Regards
Al
