Author Topic: wiring loom in steering column  (Read 3859 times)
Basil
« on: October 11, 2014, 17:48:31 »
Hello ! I am changing from manual to powersteering in my 1964 230 SL.
Therfor I need to change the long steering column for the short one.
Is there a simple way to take out the wiring loom from the steering column ?
Thank you for your answer in advance.
Paul.
mbzse
Re: wiring loom in steering column
« Reply #1 on: October 11, 2014, 18:05:31 »
Quote from: Basil
.../...1964 230 SL.../...Is there a simple way to take out the wiring loom from the steering column?
In order to remove the cables, as it is quite a restricted diameter inside the 230SL column, you need to remove the contact shells (housing halves) at the end. Be sure to mark up and photograph before you pull the pins out of the shells.
Will you be exchanging the blade springs in the front suspension as well?
/Hans in Sweden
« Last Edit: October 12, 2014, 17:01:27 by mbzse »
/Hans S
Basil
« Reply #2 on: October 11, 2014, 18:35:03 »
Hello Hans, do you mean to solder loose the wires from the plug ?
I have no intension to exchange the blade springs, but I suppose you ask this for a certain reason.
Right ?
mbzse
« Reply #3 on: October 11, 2014, 19:19:54 »
Quote from: Basil
do you mean to solder loose the wires from the plug?
You open the two halves of the shell, pull out the pins, wires remain soldered on
Quote
Blades have different length on cars with power steering. Different caster angle specification
Read more here: http://www.sl113.org/forums/index.php?topic=20014.msg141661#msg141661
/Hans in Sweden
« Last Edit: October 13, 2014, 10:52:20 by mbzse »
/Hans S
Basil
« Reply #4 on: October 11, 2014, 19:22:14 »
Thanks for the advice Hans !!
