Author Topic: Fuel gauge/ sender problem  (Read 4990 times)
nahuston
« on: October 13, 2014, 21:04:45 »
I need some help tracking down a fuel gauge issue. When I turn the key on the gauge pegs full all the time. The low warning light still works. I assumed there was a short to ground somewhere in the harness but I have checked and there is not. I have swapped gauges and it still pegs (with the sender plugged in or unplugged). Does anyone know what resistance I should see on the wire to the gauge (blue green)? Is it expected that the gauge would peg full with the sender unplugged? I would expect it to drop to zero not full but maybe its different in these cars?
nahuston
Re: Fuel gauge/ sender problem
« Reply #1 on: October 14, 2014, 13:57:14 »
I found another 230sl and unplugged the sender - the gauge pegged full. Looks like a need a sender. I have the early style, in reading here it looks like I can't use the newer style "tube'? Is that correct?
WRe
« Reply #2 on: October 14, 2014, 14:09:53 »
the early 230SL (until 1964/65) had an arm of lever sender, later than all the same tube; see http://www.sl113.org/wiki/Fuel/SenderUnit.
...WRe
jf308
« Reply #3 on: October 14, 2014, 17:41:37 »
MB Classic center just sold me a "tube style" for my 64 230 SL and that is war came out of the old tank.  Will let you know if it functions shortly.
John
scoot
  • USA, CA, Altadena
« Reply #4 on: October 14, 2014, 21:49:35 »
My understanding is that the tube-style sender and the float-style sender are not interchangeable.
Scott Allen
'67 250 SL (early)
Altadena, California
« Reply #5 on: October 25, 2014, 07:35:59 »
There are  early and late "tube style" I believe.  The lever type and early tube style are interchangeable.  The later tube style (most common) and the lever style are not unless the gauges are change also. I have taken both tube styles apart and one has three vertical wires and the other has two vertical wires.
scoot
  • USA, CA, Altadena
« Reply #6 on: October 25, 2014, 13:37:25 »
That is very interesting and something I have never heard before.  If you have pictures please post.  Would the early style tube sender correspond to an early Fintail also?
Scott Allen
'67 250 SL (early)
« Reply #7 on: October 27, 2014, 04:26:18 »
I believe so Soot.  I'll see if I have some around to photograph.
