Author Topic: Horn Ring Rattle  (Read 4128 times)
nirmal
Horn Ring Rattle
« on: October 18, 2014, 05:31:49 »
The horn ring on my 280 sl rattles which can be quite annoying. As per  the Technical Manual this is an easy fix and I need to replace the A1154640035 Fixing sleeve. Unfortunately I cannot find this with the vendor in Germany. Any suggestion?
Nirmal
1969 280sl
1953 MG TD
2012 Jaguar XJ
WRe
Re: Horn Ring Rattle
« Reply #1 on: October 18, 2014, 06:57:52 »
are you sure with the spare part you mentioned because these are the fixing sleeves (3) of the horn pad?
I would assume that the springs of the horn mechanism is broken or bad.
...WRe
« Last Edit: October 18, 2014, 07:03:18 by WRe »
scoot
  • USA, CA, Altadena
« Reply #2 on: October 18, 2014, 13:45:43 »
My steering wheel on my 1963 Fintail "clunks" at certain angles.  I'm concerned because I adjusted the screws on the contact ring pictured and think I should not have.  I'm going to pull the steering wheel and try to figure out why it clunks.  In particular it clunks when I back down the driveway and have fine adjustments to steering to navigate down the driveway.   This is of course only after I replaced the shift bushings in the column manual transmission, which required removal of the steering bearing, so I'm suspicious that I replaced something in there wrong....
Scott Allen
'67 250 SL (early)
Altadena, California
