Author Topic: Glove box door hinge  (Read 22639 times)
Re: Glove box door hinge
« Reply #25 on: February 14, 2007, 15:25:57 »
James,
also take look at the "screw" topic #4866 that you started awhile ago.
« Last Edit: February 14, 2007, 15:26:17 by 66andBlue »
« Reply #26 on: February 14, 2007, 18:10:34 »
Thanks Alfred! Shows you the state of my memory...  :oops:  I know the mismatched screws have bugged me for a longtime -- its just that it comes to the frontburner whenever I have to pull things apart (like last weekend's adventure).
mbz.280sl
  • USA, MA, Cape Cod
« Reply #27 on: February 15, 2007, 10:40:38 »
This is great, I was also trying to find those cup or finish washers. Thanks.
I was wondering about the two black plugs that was asked about in James note, referring to a picture of Douglas's glove box. Are these available?
Are they just intended to be small bumpers for the closing of the glove box?
Otto
Otto
1969 280SL, 4 speed manual, AC,  Sand Beige
« Reply #28 on: February 15, 2007, 11:30:20 »
Those little plugs should be available at any number of auto parts stores or even flea markets. I replaced mine, and I think I started with the Benz replacement part and it was not the right fit. So I went to Autozone or some such and just looked through the rack until I found something that was about right. The trick is to not get something too thick, as that adds to the already finicky process of aligning the door.
« Reply #29 on: February 15, 2007, 22:06:53 »
Well, I luckily stumbled upon some acceptable plugs while I was searching for the cup washers. The local hardware store had them, 10 cents a piece. Several colors to choose from (I did black). These are really thin, with a little star-shaped plug that goes into a phillips screwhead.
« Reply #30 on: February 15, 2007, 23:31:51 »
Otto
Otto,
Yes, those are little bumpers to cushion the door as it swings shut.
