The new rocker arrived from MB yesterday and Ronni and I had a few hours on it this afternoon. The fit is much better and a much better start point so that is heartening. I was starting to feel very depressed about the whole thing....
You can see the difference in fit of the two in these pictures, they are both clamped in the same position, I had already fettled the original rocker a bit before I took these pictures, the first time I clamped it up the gap below the door was over an inch!
Anyway it didn't take much to get the new one to slot in nicely so I then stayed on and drilled some holes for plug welds where I won't be able to get 'The Chief' into position to do a pinch type spot weld. I'll grind them down after and use the single sided spot to do some dummy welds.
I am stripping the paint off a Corvette at the moment and I was planning to strip the black off the new rocker, what does everyone think? Good idea or not? I'm not sure what the black is, whether it is better to key it up and prime/topcoat over it or take it off and prime directly on to bare steel.
Anyway I feel a lot happier about things, back to where I should have been a week and another £400 ago...I'm putting this one down to experience, what I should have done was buy two new ones from MB so at least I would have had some comeback but I was too cheap and went the ebay route, now it's wound up costing me slightly more, learn from my experience boys and girls!
Having looked at the two side by side I think the original replacement rocker could be made to fit by squeezing the two parts together and re welding the jacking points in, I am too stressed/busy/lazy/not skilled enough to deal with it but if anyone wants it they can have it. It would be good for repair sections at the very least.
Andy was right, this is making me stronger.....
