Things didn't go that smoothly for me last Saturday. I had to tackle the lower front inner fender. I guess the battery had leaked in the past and corroded just the area underneath it. I had already tried to let a patch in before but it really went badly so I gave up on that idea and got a complete inner fender for the repair. I didn't fancy trying to replace the whole panel and it seemed over the top for the amount of rust there was. I am also quite keen to retain as many of the original spot welds as possible in the engine bay area, particularly where the fenders join to the inner wing.
Even though I was using a genuine Mercedes panel there are several differences between the new inner fender and what I have in the car so I figured I'd keep the repair small and just use what I need. What could possibly go wrong?
Once I had measured how much I'd need I cut the piece off and set to dollying the flat part into a round shape again to meet up with the original on the car, that went quite well and it all looked pretty close. There was also an extra hole and dimple in the new part that needed knocking out and filling in. Once that was done I then sandblasted the new piece and cleaned it up ready to go in. I was quite pleased with the way it was all looking, I should have quit while I was ahead.
It took forever to cut out the original piece and trim the new part to fit, I had originally planned to replace the whole front corner but was concerned that I wouldn't be able to get access to the front part of the panel to weld or clean it up after, also the front part was in perfect condition so I made the join on the radiator support. I also had to replace more of the panel than I had originally planned as there was a bit of pitting further up the panel and I figured it would make welding the new piece in difficult if the metal was thinner there. I had hoped to keep the repair underneath the battery tray so it wouldn't have been obvious there had been a repair there.
I guess by that time I had just run out of talent as the welding really didn't go well.I kept blowing through so turned the welder down a bit, it was all a bit of a struggle and didn't look very nice, to be honest I'd kind of had enough by then so I should have called it a day but I was keen to get as much done as I could, besides that couple of weeks back Ronni said if I got home too early on a Saturday I could help her with the housework, she might have been joking but I just can't take that risk.
Anyway it is what it is, I would have liked it to look a bit neater. I haven't finished cleaning it up yet and I still have to spot weld the flange to the chassis rail so it may look a bit better by the time that is all done. I really had had enough by then so I called it a day, the highs and lows of car restoration eh!
